skippermikeb's avatar
skippermikeb
What does an amber, rather than usual white, light indicate on one of the device lights?
I currently have two computers connected to the routeer.  The indicator lights have always shown white for the respective two connections.  Now one is showing amber??
  • Amber means it's running at 100 Mbps instead of 1 Gbps. I'd try a new cable if you're sure your PC is capable of 1 Gbps speed
    • skippermikeb's avatar
      skippermikeb
      I followed the sleeping computer suggestion and "woke up" the one sleeping computer - router light still amber??
      • microchip8's avatar
        microchip8
        Master
        You didn't mention you had a "sleeping PC". If a PC sleeps and WoL (Wake on LAN) is enabled, it runs at 10 Mbps and the router reflects this. If the PC is then fully booted and the router still shows amber light, either it's negotiating at 100 Mbps or you may need to try a different cable for 1 Gbps white light
