JRodr's avatar
JRodr
Tutor
Jan 08, 2022
What does Firmware Version 1.3.3.142 - Hot Fix correct in R7000P Router?
What does Firmware Version 1.3.3.142 - Hot Fix correct in R7000P Router?  There is no documentation about what the specific vulnerabilities addressed by the firmware is.  I couldn't find anything in the knowledge base either.
    • JRodr's avatar
      JRodr
      Tutor
      Thanks but already saw that. The way it is organized it is not very helpful. They should include for each specific firmware release notes the security vulnerabilities and bugs fixed per router model. How I can easily get all the vulnerabilities for R7000P and easily determine what firmware addresses them.
      • JRodr's avatar
        JRodr
        Tutor
        Also the latest hot fix or firmware release notes just says
        Security Fixes:
        Fixes security vulnerabilities.
        With url to a page with all vulnerabilities listed but not organized by product.
