jhernandez138
Feb 08, 2016Aspirant
What happened to the R7000 firmware 1.0.6.28?
I went to the download site on netgear.com and no longer see the 1.0.6.28 or 1.0.5.XX firmware. What happened to them? Should I be uninstalling and reverting back to an older version?
jekriske
May 06, 2016Aspirant
Keep using port forwarding and just wait... It's very buggy.
It's not wise to continue running it at five sites if even the manufacture pulled the firmware. Your anecdotal evidence doesn't mean the firmware actually works properly.
pierreca
Mayby Netgear did pull because , like mentionned before complaints.
After trying all the firmwares since last december only 1.0.6.28 did every thing i needed and still does.
Like you mentionned buggy, did have that problem , did factory reset and re-entered all port forward, no issues since.
Even got Wake-up-on-lan working remotely properly through VPN.
so just saying from experience.
Have a great day
- JamesGLMay 11, 2016NETGEAR Employee Retired
Hi All,
For more information regarding the pull out of v1.0.6.28 you may check the link below.
