selmon89
Apr 27, 2023Follower
What is the best out of the 3
NETGEAR - Nighthawk R6900 AC1900 Smart WiFi Router NETGEAR - NETGEAR - Nighthawk R7450 AC2600 Smart WiFi Router NETGEAR - Nighthawk R7000 AC1900 WiFi Router - Black Which one is the best one to ge...
microchip8
Apr 27, 2023Master
The R7450
The other ones are slower *and* older.
- plemansApr 27, 2023Guru - Experienced User
For cheaper, amazon has the WAX206 on sale for significantly less.
Its a business class access point but has a router mode and a incoming 2.5gig wan port.
Plus its an AX3000 with wpa3. A much better device than the others for cheaper.
That's what I'd do. Current technology, future proofed a bit with a 2.5gig wan port
- michaelkenwardApr 27, 2023Guru - Experienced User
For some reason, that device has produced more than its fair share of problems here. Maybe that explains why Netgear is dumping it at discount prices.
The problems can boil down to inexperienced users who may have a problem with "business" hardware that is not intended for the consumer market.
Start at the beginning, There is no such thing as "best".
What does selmon89 want tp achieve and how much do they want to pay? Picking some random models from what looks like an ancient list isn't the best way to start.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
michaelkenward If we didn't recommend something because there were posts on here about it, we wouldn't be able to recommend anything. A lot I'd attribute to user error and that probably increases a bit when you take a business device and use it for consumers. They're not used to it. But for the price, that device has the capabilities of much more expensive devices with its 2.5gig wan. I'm really tempted to buy one myself but I have to much "S" around as it is.
I'd take a shot on it and if it doesn't work well for the OP, Amazon has a pretty generous return policy
