selmon89
Apr 27, 2023Follower
What is the best out of the 3
NETGEAR - Nighthawk R6900 AC1900 Smart WiFi Router NETGEAR - NETGEAR - Nighthawk R7450 AC2600 Smart WiFi Router NETGEAR - Nighthawk R7000 AC1900 WiFi Router - Black Which one is the best one to ge...
Apr 27, 2023Guru - Experienced User
michaelkenward If we didn't recommend something because there were posts on here about it, we wouldn't be able to recommend anything. A lot I'd attribute to user error and that probably increases a bit when you take a business device and use it for consumers. They're not used to it. But for the price, that device has the capabilities of much more expensive devices with its 2.5gig wan. I'm really tempted to buy one myself but I have to much "S" around as it is.
I'd take a shot on it and if it doesn't work well for the OP, Amazon has a pretty generous return policy
michaelkenward
My message was just there as a warning. That model has confused several people recently.
"Buyer beware" seems to be appropriate in this case, especially when someone turns up asking about a choice between a list of essentially obsolete models from 2014 to 2018.
Maybe selmon89 is looking to buy second hand.
