ArronLeeds
Aug 01, 2016Follower
What is the best R7000 firmware that support dd-wrt?
so i bought this router and have heard it supports the likes of dd-wrt, what is the best firmware for this router and how do i go about installing it?
- Aug 09, 2016
As far as NETGEAR is concerned, we do not recommend the use of 3rd party firmware since it will void its warranty.
We always recommend that you update to the latest firmware version.
Retired_Member
Aug 01, 2016That's a loaded question, since you have to ask I would suggest you use NG FW. While many swear by 3rd party it's a risk that may come back to bite you in the _$$.
jguerdat
Aug 02, 2016Guru
Since 1.0.7.2 is now available with just the briefest release note (fixes NTP issue), what is new/fixed/changed? Does it support Arlo (needed for my installation)? What else?
- Retired_MemberAug 02, 2016
Seeing how I have nothing better to do today I'll try it. BBL
No Arlo at first glance. I'll be back after I reload my settings.
- jguerdatAug 03, 2016Guru
Any luck? Or is the silence telling? :p
