ArronLeeds
Aug 01, 2016Follower
What is the best R7000 firmware that support dd-wrt?
so i bought this router and have heard it supports the likes of dd-wrt, what is the best firmware for this router and how do i go about installing it?
- Aug 09, 2016
As far as NETGEAR is concerned, we do not recommend the use of 3rd party firmware since it will void its warranty.
We always recommend that you update to the latest firmware version.
jguerdat
Aug 02, 2016Guru
Since 1.0.7.2 is now available with just the briefest release note (fixes NTP issue), what is new/fixed/changed? Does it support Arlo (needed for my installation)? What else?
Retired_Member
Aug 02, 2016Seeing how I have nothing better to do today I'll try it. BBL
