ArronLeeds
Aug 01, 2016Follower
What is the best R7000 firmware that support dd-wrt?
so i bought this router and have heard it supports the likes of dd-wrt, what is the best firmware for this router and how do i go about installing it?
- Aug 09, 2016
As far as NETGEAR is concerned, we do not recommend the use of 3rd party firmware since it will void its warranty.
We always recommend that you update to the latest firmware version.
Retired_Member
Aug 03, 2016I reverted to previous FW 1.0.5.70 for now.
ElaineM
Aug 09, 2016NETGEAR Employee Retired
