orangeandblue1's avatar
Nov 02, 2019
What is the difference between AIO and VPN Fresh Tomato firmware versions?
I'm considering changing from the Netgear firmware (because the one that is the "latest greatest" (not) for the R7000 Nighthawk is junk) to Fresh Tomato. I noticed when downloading the different firmware versions of Fresh Tomato that there is an "AIO" and a "VPN" version. What is the difference and does it matter that much? Thanks.
  • AIO is full featured without VPN. VPN is just VPN added.
    • myersw's avatar
      myersw
      Master
      By the way this forum is not the place to ask questions like this. This question and anything else should be on the appropriate forum. This forum is Netgear only questions/issues.
      • antinode's avatar
        antinode
        Guru
        > [...] this forum is not the place to ask questions like this. [...]
           Who made you King of the Forum?
           I'd expect to get/find more/better information about alternate
        firmware for a Netgear router from the folks who distribute the
        alternate firmware, but the title of the forum is "Nighthawk WiFi
        Routers", not "Nighthawk WiFi Routers Running Netgear Firmware Only --
        All Others Keep Out!".  Or did I miss something?
           Or are you just upset by any thread where you can't justify posting
        yet another complaint about Netgear firmware?  (As if you needed any
        valid justification.)
