StanH
Jun 22, 2023Tutor
What is the function of this on my Readyshare USB drive?
I have a 7000 router with a ReadyShare USB SSD. My Windows 10 File Explorer shows the following folders. I do not know what they are or how they got there. Does anyone know if they would be serving s...
michaelkenward
Jun 22, 2023Guru - Experienced User
Which "7000" is that?
ReadyShare is Netgear's way of sharing files on drives plugged into the USB ports on the router.
Plug that USB drive into a PC and you will see the same files.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual about ReadySHARE.
