NetgearNetowkri
Apr 15, 2017Tutor
What is the latest update on this Router?
Back in Dec 2016, I received an e-mail from Netgear with a link to a new Security Update for my R8000 Router. I was not able to complete the update until now. The link on the e-mail was for update:...
- Apr 16, 2017
You can always find the latest official firmware on the support pages for your device:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
This says the latest is Firmware Version 1.0.3.36.
The manual there will also tell you how to update the firmware yourself. It comes as a zip file that you have to unpack to get at the .chk file.
michaelkenward
Apr 16, 2017Guru - Experienced User
- NetgearNetowkriApr 16, 2017Tutor
Thanks so much for your answer!! That is the update that the Router said that I needed to do. Thanks again!
