terryalbert
Apr 10, 2023Follower
What is the purpose of setting up a DHCP pool range in the WAX214-AX1800?
1 Reply
What is the purpose of setting up a DHCP pool range - Google Search
If, like me, you aren't clear about what it means, you probably don't need it.
If you have an issue with the WAX214 that you are trying to fix, tell people what that is.
But that might be better posted in the appropriate section:
Business Wireless - NETGEAR Communities
