soaxm1
Jun 17, 2017Follower
What is the setting HT160 for?
HI, I'm new to the Community. I bought a new Netgear and have configured it but there are some setting I'm not familiar with and want to know what these setting do or what they are for. As I come...
- Retired_MemberJul 17, 2017
According to the help section on the bottom it says "HT160 can improves 11ac WiFi performance" notice the error in gramma, but I can never enable mine, I just think its one of the many problems on this BETA or should I say ALPHA Router people are getting, the list grows every day.
Regards
Retired_Member
Jul 17, 2017According to the help section on the bottom it says "HT160 can improves 11ac WiFi performance" notice the error in gramma, but I can never enable mine, I just think its one of the many problems on this BETA or should I say ALPHA Router people are getting, the list grows every day.
Regards
ElaineM
Jul 18, 2017NETGEAR Employee Retired
Enabling this option (HT160) will increase the channel width and speed provided that your wireless clients must also support HT160.
For the grammar, I have forwarded it to the proper department to have it corrected.
Thank you!
