HappyMonday2021
Jan 18, 2021Follower
What NetGear Routers can run ExpressVPN on the Router Firmware?
What NetGear Routers can run ExpressVPN on the Router Firmware? How can you set up the ExpressVPN router app for Netgear routers? NetExpressVPN ExpressVPN_Help
1 Reply
expressvpn is 3rd party firmware. You won't find help/support on the official netgear forums for it.
You can try the express vpn forums or even just look at their compatible router list.
