GNUguy's avatar
GNUguy
What's the latest firmware version?
Seeing two different FW versions for my router. My current FW version is 1.3.1.44_10.1.23. When I check for update, the NetGear app on my system reports 1.3.1.64_10.1.36. When I check the download ...
  • microchip8's avatar
    Dec 23, 2020
    The NG site is correct. NETGEAR is usually slow in adding new firmware versions to its download site
    Also, I advice not to use apps to upgrade firmware and also don't use WiFi. Use a wired connection for firmware updates. Too many people brick their routers updating with app and over WiFi
