paulja
Jul 03, 2022Tutor
What's the word on Zuorat?
Who is affected? How can we check? How do we fix?
- Jul 05, 2022
Hello NETGEAR Community,
We’re unaware of any specific NETGEAR devices impacted because details are scarce on how this purported nation-state sponsored malware operates, but if you have reason to believe you’re impacted, we recommend doing a factory reset and installing the latest firmware as described at https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser.
Thank you,
Christine
Jul 03, 2022Guru - Experienced User
NG is looking into this as of last Tuesday:
If you are a NETGEAR customer with a security-related support concern, you can contact NETGEAR customer support at [email protected].
For all other issues, visit http://www.netgear.com/about/security/
