Nisin
Jun 07, 2021Aspirant
Whats up with this R7000 (odd light pattern)
I picked up a r7000 ( no clue if its stock fw or something else). When I plug it flashs some lights then cycles the following pattern. _ _ _ _ _ _ _ _ _ _ _ _ (3 sec) _ _ _ _ _ _ _ _ _ _ _...
Nisin
Jun 09, 2021Aspirant
I tired to factory reset and it still does the same thing.
The disco routine never stops. It keeps repeating the same cycle over and over.
Nisin
I tried tftp following this guide
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Thing is, it doesnt seem to connect.
I had the Network Connections window open in windows and noticed the connection would say
Enabled
Identifying
Netowrk cable unplugged
Seemed rather random and not corresponding with the the lights.
Sometimes it would do it twice in a row and other times nothing.
- antinodeJun 09, 2021Guru
"tired" how, exactly? Did pressing the button have any effect on the
LEDs?> Netowrk cable unplugged
If the Windows system doesn't see it as a physically live Ethernet
connection, then there may be little hope.
> Would my next step be: [...]If you can't get a network connection to it, then the serial port may
be all that's left.> [...] Thing is, it doesnt seem to connect.
"seem"? Actual commands/actions? Actual error message?
> Sometimes it would do it twice in a row and other times nothing."it"?
- michaelkenwardJun 10, 2021Guru - Experienced User
This is more recent.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
It includes details on using TFTP from Windows rather than a third party client.
If a standard factory reset fails, there is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.You have to do everything in the correct order, paying careful attention to any messages that you see.
- NisinJun 10, 2021Aspirant
antinode wrote:> "tired" how, exactly? Did pressing the button have any effect on the
LEDs?None
be all that's left.Im starting to think that also.
michaelkenward wrote:> If a standard factory reset fails, there is more severe, recovery reset, that you could try:
I tired doing this, but the reset button looks to be unresponsive. Pressing it does not stop the light pattern.
