acecryz
Nov 08, 2018Aspirant
When I do a speed test through my R7000 my speed gets cut in half.
I tested my connection to the main modem/router wired all of my wires are at least cat 5e and my speed are about 900mbps (local) which is right about where I expect it to be. However when I connect i...
- Nov 19, 2018
I decided to get a small switch instead, I get to keep my 900 mbps and my wifi. Sadly, I can't access routerlogin.net anymore though my pc.
shamarin
Nov 08, 2018Virtuoso
Try the previous build 1.0.9.34. FW 1.0.9.42 is buggy.
StickyNote
Nov 09, 2018Guide
Go back to V1.0.9.32_10.2.34 firmware make sure to do a reset after the flash. Set the corret time and complete the setup test it. I could not get 1.0.9.34 to function 100 percent or the latest release firmware either. Netgear made some changes to the GUI in the firmware 1.0.9.34. Messed up the time sync.
- shamarinNov 09, 2018Virtuoso
Sync time is not missed up, it's just moved to new place schedule section
- StickyNoteNov 09, 2018Guide
Sync time is messed up. For the router I have R7000 it would keep the correct time for aprox 24 hours or less than. Then the performace along with the correct time became an issue.
Go to advansed setting tab and then to security - schedule. Here you can setup your time zone and NTP server via witch router will sync date and time.
