acecryz
Nov 08, 2018Aspirant
When I do a speed test through my R7000 my speed gets cut in half.
I tested my connection to the main modem/router wired all of my wires are at least cat 5e and my speed are about 900mbps (local) which is right about where I expect it to be. However when I connect i...
- Nov 20, 2018
I decided to get a small switch instead, I get to keep my 900 mbps and my wifi. Sadly, I can't access routerlogin.net anymore though my pc.
shamarin
Nov 09, 2018Virtuoso
Sync time is not missed up, it's just moved to new place schedule section
StickyNote
Nov 09, 2018Guide
Sync time is messed up. For the router I have R7000 it would keep the correct time for aprox 24 hours or less than. Then the performace along with the correct time became an issue.
- shamarinNov 09, 2018Virtuoso
Go to advansed setting tab and then to security - schedule. Here you can setup your time zone and NTP server via witch router will sync date and time.
- StickyNoteNov 09, 2018Guide
Not asking how to. Read your person messages in the community mail.
