acecryz
Nov 08, 2018Aspirant
When I do a speed test through my R7000 my speed gets cut in half.
I tested my connection to the main modem/router wired all of my wires are at least cat 5e and my speed are about 900mbps (local) which is right about where I expect it to be. However when I connect i...
- Nov 19, 2018
I decided to get a small switch instead, I get to keep my 900 mbps and my wifi. Sadly, I can't access routerlogin.net anymore though my pc.
acecryz
Nov 20, 2018Aspirant
I don't have isolated networks as I now run my R7000 in AP mode. I bought a R7000 because I was sick and tired of cheap access points I thought getting a decent netgear one would solve my problem. For the most part it did. You just come here and insult my purchase and ignore the fact that this router shouldn't be CUTTING MY SPEED IN HALF. "I HARDLY UNDERSTAND WHY DOES ONE COMMENT IGNORING THE MAIN PROBLEM."
schumaku
Nov 20, 2018Guru - Experienced User
The AP mode on these consumer routers suffer in many aspects. Often the Gigabit Ethernet ports aren't performing at full speed, because of some hardware acceleration isn't available (or used) by the firmware in AP mode, why ever: The GbE ports are handled as individual ports by the firmware, and are not configured for using the fast hardware switch. It's an internal design of the past, see also the need to disable the QoS when operating in router mode on fast Internet connections. That's probably exactly the point that hits your R7000 installation.
And sorry, there was no indication that your R7000 is operating in AP mode.
