NettyJim17
Feb 19, 2021Aspirant
When I download the newest firmware, the download is a .ZIP containing, a .CHK, and a HTML file?
My current router version is: 1.3.1.64_10.1.36....but the newer version is, 1.3.2.134. > ADMINISTRATIVE, FIRMWARE UPDATE, then after downloading the newer firmware to my DOWNLOADS, the ZIP file...
michaelkenward
Feb 20, 2021Guru - Experienced User
> ADMINISTRATIVE, FIRMWARE UPDATE, then after downloading the newer firmware to my DOWNLOADS, the ZIP file is nothing more than a .CHK file, and an HTML.
This might he useful:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
antinode
Feb 20, 2021Guru
> This might he useful: [...]
So useful that suggesting it only once wouldn't have been adequate?
Reading before posting can avoid some wasteful redundancy. Perhaps
you should try it from time to time.
