tedio
Sep 14, 2018Tutor
Where can I change the user name admin?
- Sep 15, 2018
> [...] I don't see how to add a user to use instead of admin. [...]
Netgear doesn't provide a way to do that.
> [...] I am concerned with security. [...]
Ok. Please explain how a different user name would improve security
more than using a longer password.
antinode
Sep 14, 2018Guru
> Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Is that accurate? Firmware version?
Perhaps on some other router, or with some future firmware version on
your router?
If you think that using a different user name for the administrator
account would improve security, them you might consider adding your
proposed alternative user name to your current "admin" password.
- tedioSep 15, 2018Tutor
The firmware is V1.0.2.60_10.0.44, The hardware is R6700v3. I am concerned with security. I don't see how to add a user to use instead of admin.
- antinodeSep 15, 2018Guru
more than using a longer password.- tedioSep 16, 2018Tutor
You already know the answer to that but I except your answer. Only wish they would add the feature in a future release. Thank you for your reply.
