mamuzzini
Jun 17, 2022Aspirant
Where do I find the 8 digit PIN
mamuzzini
Need the security key. I telework and need it for my job
Jun 17, 2022Guru - Experienced User
You gave us nothing to go off. Like what NetGear product are you referring too?
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
