fractaloon
May 26, 2022Follower
Where is the time zone setting on Nighthawk X4S R7800
I was trying to change my timezone and couldn't find the setting.. Everything I read said it is in Advanced tab under Security -> Schedule. It wasn't there and I found another post saying as much bu...
- May 27, 2022
fractaloon wrote:
Advanced tab under Administration -> NTP Settings
It can depend on the firmware installed on the device.
Things have moved over time.
So if that doesn't work, check your firmware version.
Kitsap
May 26, 2022Master
Advanced -> Administration -> NTP Settings
See attached.
