fractaloon
May 26, 2022Follower
Where is the time zone setting on Nighthawk X4S R7800
I was trying to change my timezone and couldn't find the setting.. Everything I read said it is in Advanced tab under Security -> Schedule. It wasn't there and I found another post saying as much bu...
- May 27, 2022
fractaloon wrote:
Advanced tab under Administration -> NTP Settings
It can depend on the firmware installed on the device.
Things have moved over time.
So if that doesn't work, check your firmware version.
michaelkenward
May 27, 2022Guru - Experienced User
