joed9988
Mar 23, 2024Aspirant
Where to find cable connection information R90000?
my old modem was a netgear c7800 and i could go into the firmware and check the cable connection and it would show me the signal strength from the cable company the dbmv. i cant seem to find this in...
- Mar 26, 2024
issues resolved they are back working factory reset seemed to corrupt the firmware and i couldn't access the configuration software i was getting a 404 error on both devices. i ended up doing a 2nd factory reset and the error went away and i was able to configure both devices again. just frustrating when things don't work as they should. i guess i should have done the 2nd factory reset before complaining.
joed9988
Mar 24, 2024Aspirant
i do have a netgear modem ahead of the router is there a way of connecting to the firmware with out unpluging the router?
michaelkenward
Mar 24, 2024Guru - Experienced User
If this is a Netgear cable modem and that is the device that you want to update, forget it.
You have no control over the firmware on your cable modem.
