joed9988's avatar
joed9988
Where to find cable connection information R90000?
my old modem was a netgear c7800 and i could go into the firmware and check the cable connection  and it would show me the signal strength from the cable company the dbmv. i cant seem to find this in...
  • joed9988's avatar
    joed9988
    Mar 26, 2024
    issues resolved they are back working factory reset  seemed to corrupt the firmware and i couldn't access the configuration software i was getting a 404 error  on both devices. i ended up  doing a 2nd factory reset  and the error went away and i was able to configure both devices again. just frustrating when things don't work as they should. i guess i should have done the 2nd factory reset before complaining.
