Yournumbersup
Feb 26, 2020Aspirant
Which is the most reliable firmware update for the R7900P — Nighthawk X6S AC3000 Tri Band WiFi Route
I need to update the firmware on my Nighthawk X6S AC3000 Tri Band WiFi Router. My current firmware version is: V1.4.0.10_1.2.14. Could some let me know which version is the most stable? Thank you ...
- Feb 27, 2020
Truthfully? the majority work fine.
You see a lot of complaints about firmware because this is where people come with issues. Most devices work fine. I'd do the latest update following how I suggested it. Most don't have an issue. If you're one of the unlucky few who do, you can downgrade easily. Especially if you made a backup.
The most complained about firmware and device is the R7000. but if you look at reviews, it does great. But Netgear sells a ton of them so even if only a few percentage points have issues, we see it on the forums. Its tough to keep in mind of members of the forum because we see it frequently.
Like I said, I'd try the update and see how it works for you. You could even try the auto-update. I'm not a fan of it because when we see corrupt firmware on here its either a result of auto update or updating over wifi. But it does work.
Yournumbersup
Feb 27, 2020Aspirant
That is what I is what I was concerned about.
Feb 27, 2020Guru - Experienced User
You're several version behind. If you weren't using itunesServer, kwilt photo sharing, time machine, tivo, downloader, then I'd try the upgrade. Most users didn't have issues but those that did, we usually have downgrade to the version prior to them being removed.
Also, people have had the best luck when they upgrade of a hardwired connect, factory reset afterwards, and then do a manual install. I specify manual because it seems backup configurations seemed to cause issues when those features were removed.
You could always take a backup configuration and if the upgrade does cause you issues, downgrade back down and re-install the backup. would make the downgrade go faster for your.
- YournumbersupFeb 27, 2020Aspirant
What is the firmware that you think works the best? I have had other Netgear routers that did not work well with later updates.
- plemansFeb 27, 2020Guru - Experienced User
