Yournumbersup
Feb 26, 2020Aspirant
Which is the most reliable firmware update for the R7900P — Nighthawk X6S AC3000 Tri Band WiFi Route
I need to update the firmware on my Nighthawk X6S AC3000 Tri Band WiFi Router. My current firmware version is: V1.4.0.10_1.2.14. Could some let me know which version is the most stable? Thank you ...
- Feb 27, 2020
Truthfully? the majority work fine.
You see a lot of complaints about firmware because this is where people come with issues. Most devices work fine. I'd do the latest update following how I suggested it. Most don't have an issue. If you're one of the unlucky few who do, you can downgrade easily. Especially if you made a backup.
The most complained about firmware and device is the R7000. but if you look at reviews, it does great. But Netgear sells a ton of them so even if only a few percentage points have issues, we see it on the forums. Its tough to keep in mind of members of the forum because we see it frequently.
Like I said, I'd try the update and see how it works for you. You could even try the auto-update. I'm not a fan of it because when we see corrupt firmware on here its either a result of auto update or updating over wifi. But it does work.
Yournumbersup
Feb 27, 2020Aspirant
What is the firmware that you think works the best? I have had other Netgear routers that did not work well with later updates.
Feb 27, 2020Guru - Experienced User
