davisrandm's avatar
davisrandm
Follower
Aug 26, 2020
Which Nighthawk Routers will best support MESH networking with a MESH-enabled extender e.g. EX7500
Or, to put it another way, what router specifications will best tell me about its MESH capabilities.
Thanks for your help
  • A mesh router? Orbi
    Otherwise there isn't really a mesh router.
    A mesh extender just simply uses the same ssid as the router and allows a devices (pc/laptop/cell/etc) to roam based on a roaming protocol. A full mesh system uses a controller that runs the satellites. Mesh extenders don't have that option.
    If you're simply wanting a router to match with your extender, look at the performance of the extender and get "at least" the same performance from your router.
1 Reply
  • plemans's avatar
    A mesh router? Orbi
