banhoagni
Dec 12, 2022Follower
Which router is better: TP-Link AX3000 or NetGear NightHawk AC1900?
I’m mainly looking for best range at 5Ghz speeds (it’s a big house), especially for gaming and streaming (ethernet not applicable).
Kitsap
Dec 12, 2022Master
banhoagni wrote:I’m mainly looking for best range at 5Ghz speeds (it’s a big house), especially for gaming and streaming (ethernet not applicable).
You need to do some homework. Here is a link to a recently updated Duckware blog article. Duckware knows what they are talking about.
https://www.duckware.com/tech/wifi-in-the-us.html
The numbers you provide (AX 3000 and AC 1900) are aggregate capacity ratings from the manufactures in an attempt to allow comparison of router throughput capacities from different manufacturers. More of a marketing label. In this case, apples and oranges when you consider the additional Wi-Fi band of the AX device. You are going to need to compare actual reviews of specific model numbers of the Wi-Fi routers.
In general, AX devices are a newer fresher design compared to AC devices. Also AX devices will most likely be supported by the manufacturer farther into the future than AC devices.
