clinton113
Apr 27, 2023Follower
Which router is better TP-Link AX3000 or NetGear NightHawk AC1900?
I’m mainly looking for best range at 5Ghz speeds it’s a big house, especially for gaming and streaming ethernet not applicable. Please help me to choose best option for my house. Thanks in advance
michaelkenward
Apr 27, 2023Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- microchip8Apr 27, 2023MasterYou cannot really compare an AX router to an AC one.
Also, AXxxx and ACxxx are speeds, not router model numbers.- michaelkenwardApr 27, 2023Guru - Experienced User
And you might not get much feedback about TP-Link hardware in a Netgear group.
