clinton113
Apr 27, 2023Follower
Which router is better TP-Link AX3000 or NetGear NightHawk AC1900?
I’m mainly looking for best range at 5Ghz speeds it’s a big house, especially for gaming and streaming ethernet not applicable. Please help me to choose best option for my house. Thanks in advance
Apr 27, 2023Guru - Experienced User
How big is the home?
What actual tp-link router is it? AX3000 is a speed.
Whats the interior walls made from?
What's your budget? (that's key as well as its pointless to recommend a top end mesh/router if its not in budget)
You might be better to go with a mesh system depending on the size of the home.
