willgart
Apr 24, 2023Follower
which router support time scheduling?
Hi, I'm looking for a router which support time scheduling access control per device.
(like: blocking youtube for specific hours and specific devices only)
so which netgear router support it?
thanks.
1 Reply
- microchip8MasterMost modern AC/AX NETGEAR routers do.
Per-device blocking is not officially supported but you can go around by specifying which IP addresses are allowed to bypass the blocking so the rest of them will be blocked.
