vicorly2
Apr 22, 2021Follower
Which WiFi extender compatible with Nighthawk X10 AD7000
I would like to extend my WiFi from my Nighthawk X10 AD7000 via Ethernet to a Netgear WiFi Extender in another part of my house. Which Netgear model should I buy?
1 Reply
Netgear makes a lot of differnet extenders.
with such minimal info it tough to help.
there is a product finder on the the extender site that allows you to narrow the search by speed/features you want.
https://www.netgear.com/home/wifi/range-extenders/
Just make sure to get one that supports access point mode as that'll be the mode you need for hardwired connection
