Markg2
Sep 12, 2017Tutor
White vs. Amber (Orange) Ethernet port status LED
Model R7300DST (AC 1900) One of the ports blinks Amber/Orange vs. white. Support says, "The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps...
- Sep 12, 2017
> I know how to calc internet down/up speed [...]
More accurately, you know how to run some program which measures it.
> [...] but how can you determine the speed of data to and from
> different PC's on the peer to peer network?
There may be fancy programs available to do this, but I normally just
transfer a file (which is not trivially small), and measure the time. I
typically have an FTP server running everywhere, and binary FTP is a
pretty low-overhead protocol, so I normally time an FTP transfer. Many
FTP client programs have built-in time recording; Wget, for example:
pro3$ wget ftp://alp-l/tru64/T64V51BB27AS0006.tgz
--2017-09-12 13:51:01-- ftp://alp-l/tru64/T64V51BB27AS0006.tgz
=> 'T64V51BB27AS0006.tgz'
Resolving alp-l... 10.0.0.9
Connecting to alp-l|10.0.0.9|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done. ==> PWD ... done.
==> TYPE I ... done. ==> CWD (0) tru64 ... done.==> CWD (1) tru64 ... done.
==> SIZE T64V51BB27AS0006.tgz ... done.
==> PASV ... done. ==> RETR T64V51BB27AS0006.tgz ... done.
T64V51BB27AS0006.tg [ <=> ] 205.60M 61.5MB/s in 3.4s
2017-09-12 13:51:05 (59.7 MB/s) - 'T64V51BB27AS0006.tgz' saved [215586563]
Note that "59.7 MB/s" would be about 478Mb/s (59.7 MB/s * 8bit/byte).
Of course, this method may also incur sloth from the file I/O if that's
slower than the network I/O (which may be true in that test). A fancy
program could send dummy data, and discard what it receives, and so geta network speed value which is independent of any disk I/O.
The effort you put into any measurement depends on how much you care
about the result. I typically don't care much about such data.
michaelkenward
Sep 13, 2017Guru - Experienced User
Markg2 wrote:What makes no sense is that I don't have an internet connection that anywhere near supports gigabit speed. So why the amber light?
The lights on LAN (Ethernet) ports have nothing to do with the speed of the Internet. They tell you how fast things are moving on your local network.
The LAN ports on most recent PCs are gigabit.
