diane72
Jul 02, 2019Aspirant
Why did WiFi name change?
I want to know why my WiFi name would change? All of a sudden our internet wasn't working. I couldn't find our WiFi NETGEAR04 it was gone. I followed instructions online and connected a computer to t...
- Jul 02, 2019
Resetting back to factory is pretty easy. We always recommend a reset back to factory anytime someone does a firmware update so its a good time to check if you're firmware is current.
To reset, just hold the reset button on the back for 7-10 seconds until the lights change.
the link I had in my last post has your firmware, installation guide, and a manual there.
diane72
The odd thing is that the NETGEAR04 is the name it came with. If the reboot caused it to change it's name where did this name come from? I also had a password on it to begin with. I could do a reset back to Factory, but is this difficult to do? I set it up, so perhaps it isn't that tough.
Jul 02, 2019Guru - Experienced User
