JImbo1225
Nov 30, 2020Aspirant
Why do I have to reboot my Nighthawk X6 R8000 every week
Why is it that I have to reboot my router at least once a week? I was told this is a good router, but I am having my doubts. What can be done to fix this?
michaelkenward
Nov 30, 2020Guru - Experienced User
Why do you reboot it? To solve some sort of problem?
What firmware version do you have on the R8000?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
JImbo1225
Dec 01, 2020Aspirant
I apologize as my information was incomplete. The reason I am rebooting each week is that all of my devices on WiFi are not able to connect to the Internet. The connection drops - first I can usually tell by my cell phone, and then other WiFi devices will lose their Internet connection. I have checked for the latest firmware - presently the version shows as V1.0.4.62_10.1.74. I have reset the modem to factory specs and still have this issue. I understand that a reboot is needed when there is a new firmware version, but I feel I should not have to reboot literally every week.
- michaelkenwardDec 01, 2020Guru - Experienced User
Is it just the wifi that dies, or the whole Internet?
What do the LEDs on the device show when this happens, particularly the wifi LEDs.
Do you have anything wired to the router? If so, does that also go off line?
Unfortunately, latest is not always greatest. It may be that an earlier version is more stable.
No, you should not have to reboot the thing.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
