JasonWise
Feb 01, 2020Tutor
Why do I have to reboot my R7000 everyday?
I recently purchase this router and was SUPER excited about it. At first, everything was GREAT! Zero complaints. Recently though, it has started acting up. I literally have to reboot the router 1-2 t...
- Feb 01, 2020
Usually not, but if you encounter any issues, a factory reset and reconfigure from scratch is recommended
microchip8
Feb 01, 2020Master
which firmware version? The only current recommended firmware that is the most trouble-free is .42. Anything above is a mess
- JasonWiseFeb 01, 2020Tutor
Firmware Version
V1.0.9.88_10.2.88- microchip8Feb 01, 2020Master
Downgrade to version .42 https://www.netgear.com/support/product/R7000#download
Click on the + sign at bottom left to expand the menu and download the firmware
Firmware Version 1.0.9.42 correct?
