JasonWise
Feb 01, 2020Tutor
Why do I have to reboot my R7000 everyday?
I recently purchase this router and was SUPER excited about it. At first, everything was GREAT! Zero complaints. Recently though, it has started acting up. I literally have to reboot the router 1-2 t...
- Feb 01, 2020
Usually not, but if you encounter any issues, a factory reset and reconfigure from scratch is recommended
JasonWise
Feb 01, 2020Tutor
Firmware Version
V1.0.9.88_10.2.88
microchip8
Feb 01, 2020Master
Downgrade to version .42 https://www.netgear.com/support/product/R7000#download
Click on the + sign at bottom left to expand the menu and download the firmware
- JasonWiseFeb 01, 2020Tutor
Firmware Version 1.0.9.42 correct?
- microchip8Feb 01, 2020Master
Yes, that's the most recommended/stable one. Later ones also remove features so NG can have space on the Flash chip for Armor
Okay thanks. Now as far as flashing an order version. There would be no issues when doing that?
