minusten
Dec 31, 2017Tutor
Why does one of my R7000P ethernet lights blink orange. I have it connected to a 4 port POE switch.
 Received a R7000P Netgear Nighthawk router for Xmas. I have it connected, but am puzzled why one of the 4 ethernet ports blinks orange.  I have this port connected to a 4 port POE switch. I can chang...
- Dec 31, 2017
minusten wrote:Received a R7000P Netgear Nighthawk router for Xmas. I have it connected, but am puzzled why one of the 4 ethernet ports blinks orange.
I have this port connected to a 4 port POE switch. I can change the connection of the router's ports (from 4 to 3 example) and the light will change numbers as to the ethernet cable connected to the POE switch. Help me out someone; do I have a faulty router?
Is the POE switch rated for 100mb or 1gb, normally amber is a 100 mb connection?
Guessing that no matter which router lan port you connect the switch to the router the results are the same?
The blinking normally shows a active data flow, steady no data flow.
antinode
Dec 31, 2017Guru
   Do yourself a favor.  Visit http://netgear.com/support , put in your
model number, and look for Documentation.  Get the User Manual.  Look
for "Table 1. LED descriptions".
   Not a very detailed description of anything.  If your "a 4 port POE
switch" has 10/100MHz ports, then that would account for the amber LED
color on the router LAN port.
