BilliJo
Aug 22, 2021Follower
WHY DOES THE NIGHTHAWK APP CRASH BEFORE IT EVEN OPENS?
Is anyone else having problems with the NightHawk App? I can't even get mine to open before it crashes. Has anyone figured out how to fix this issue? I have uninstalled it and re-installed it and it ...
ForceMOD
Sep 06, 2021Aspirant
It used to work fine months ago. Its been a while since I've used it.
- michaelkenwardSep 07, 2021Guru - Experienced User
ForceMOD wrote:
It used to work fine months ago. Its been a while since I've used it.They broke the Android version, if that is what you use, in a recent update.
It works on some Androids but nit on others. Samsung hardware seems to have been especially hard hit.
