SurlyGeezer
Sep 07, 2016Aspirant
WHY is a power reset required after Internet loss
Hi All, Can anyone explain WHY....... After a loss of service (in this case I had to unplug at the master socket to test for a phone line fault, but after any service interteruption).....afte...
- Retired_MemberSep 08, 2016
You're Welcome,
Then there's your answer, they are probably using some proprietary FW in their router/modem.
Retired_Member
Sep 07, 2016Try a reset to defaults use defaults except for WIFI, see if that makes a difference.
If the internet LED is orange remove WAN cable for a second and reconnect it......also if IPV6 is enable try disabling.....is router status you can try to renew IP too.
Some process stops when service is down and won't restart without a reboot. Try a power cycling ISP box next time.
SurlyGeezer
Sep 08, 2016Aspirant
Many thanks for taking the time to respond Retired_Member,
I have the LED's disabled so couldn't tell, but will try the WAN cable disconnect next time.
(Just to clarify....This is not a repeat problem with disconnection, it is very rare to lose service, indeed this time was as a result of me needing to access the test plug at the main BT incoming box due to a telephone line failure).
I note with interest you suggest a service may simply get interupted and therefore require a reboot.........would that be within the router iteself or the PC? (I had not tried rebooting PC)
Thanks again
I doubt it's in the router certainly not the PC, more than likely something with the ISP, you should contact them.
- SurlyGeezerSep 08, 2016Aspirant
Will get zero support as not using ISP's Router
But thanks anyway
You're Welcome,
