SurlyGeezer
Sep 07, 2016Aspirant
WHY is a power reset required after Internet loss
Hi All, Can anyone explain WHY....... After a loss of service (in this case I had to unplug at the master socket to test for a phone line fault, but after any service interteruption).....afte...
- Retired_MemberSep 08, 2016
You're Welcome,
Then there's your answer, they are probably using some proprietary FW in their router/modem.
Retired_Member
Sep 08, 2016I doubt it's in the router certainly not the PC, more than likely something with the ISP, you should contact them.
SurlyGeezer
Sep 08, 2016Aspirant
Will get zero support as not using ISP's Router
But thanks anyway
You're Welcome,
