emanon
Aug 23, 2018Tutor
Why is my R7000 slowing down my network?
I have a Nighthawk R7000. It's connected to my cable internet service provider modem via ethernet. The provider promises me 100 Mpbs and I have been getting that or just a little more or less depend...
- Aug 23, 2018
Please download the latest firmware, run a speed test, and let me know if your issue persists. You may download the latest firmware using the link below:
https://www.netgear.com/support/product/r7000.aspx#download
~Christian
Christian_R
Aug 23, 2018NETGEAR Employee Retired
- emanonAug 23, 2018Tutor
Firmware Version
V1.0.9.14_1.2.25- Christian_RAug 23, 2018NETGEAR Employee Retired
~Christian
~Christian
Wow my friend you are a genuis! That did it. I installed latest firmware and ran 3 tests. All were above 100 Mbps!! I had not set the R7000 to automtaically update beacuse sometimes updates cause problems and I like to wait and see what others experience with updates.
