lila-charlie
Jun 03, 2022Follower
Why is my Routerlogin.net not working?
I would personally recommend the following troubleshooting tips to fix the issues with the Routerlogin.net:
- You can try 192.168.1.1 in a web browser.
- You can try to power cycle the router as well as the modem. Also, restart other devices connected to the router.
- You must be connected to the wifi network of the router. The default wifi settings are located on the bottom or the back of the router.
- Just ensure that the web address which you are using is correct. Also, verify the username and the password.
- Try to use a different browser to access the login portal.
- The pop-blockers, firewalls and ad-blocking software might pose hurdles. Disable them temporarily.
- You can connect to the router via different means. Like, if you are using a wireless connection, choose a wired connection this time. You can also try to switch the device from where you are accessing the Routerlogin.net page.
- If none of the above tips proves to be helpful, reset the router to factory defaults.
No RepliesBe the first to reply
