Histrovian
Jan 03, 2021Aspirant
Why my IP went from residential to business?
I have Charter Spectrum ISP and a Netgear nighthawk ac2400 router. Im currently unable to login to a gaming server because according to them, my IP is identified as business. However, When I diere...
Jan 03, 2021Guru - Experienced User
What spectrum gateway do you have?
Are you using armor, parental controls, or a vpn?
have you tried changing the dns provider? Try googles at 8.8.8.8 or 8.8.4.4 or cloudfare's at 1.1.1.1
What firmware is on the router?
Are you playing on a xbox/ps4-5/what exactly is telling you this?
Histrovian
What’s spectrum gateway and how do I find it?
Im not using any wall or vpn.
Oh just an update, it seems like it is NOT the router that is giving me business classification. I plugged my pc directly to the modem this time and it says “spectrum business?”
It didn’t the first time. I also called my isp and they said it was residential. Very puzzling!
- michaelkenwardJan 04, 2021Guru - Experienced User
Histrovian wrote:
What’s spectrum gateway and how do I find it?Usually the modem box that connects you to the outside world.
Your problem seems to be with Spectrum.
- plemansJan 04, 2021Guru - Experienced User
did you try a different dns?
- antinodeJan 04, 2021Guru
> [...] according to them, my IP is identified as business. [...]
I'd start by asking how, exactly, "they" determined that. To me,
this whole question sounds bogus. So far as I know, the Internet is not
divided between "residential" and non-"residential". Where does one go
to see the residentiality of the IP address one has?And then, why do "they" care?
> [...] When I dierectly connect my modem to my Pc and run a speed test
> or any sort of test to see if that's the case, it says residential.
> But when I connect from my modem to my router(netgear nighthawkac2400)
> and then to my pc and run the test again, it says business."it"?
What are the IP addresses being tested in both these cases?
How, exactly, would _any_ DNS-related information affect how some
(unspecified) entity might view some (unspecified) IP address or other
as "residential" or not (whatever that might actually mean)?- HistrovianJan 04, 2021Aspirant
There is a difference between residential and business internet. Try playing the online game Diablo 2 with a business and let me know the result.
Here's an update. We are using an electrical wifi/internt extender from downstair to upstair. We just reset the two devices this morning and I got a different IP and it no longer say business. We also changed out the router, though I doubt this has anythign to do with it.
So it appears to me that the electrical extender is what's causing the issue!
