MarioHere
Jul 12, 2022Aspirant
Why netgear stopped showing my preferred network?
This is really bizarre. I used to use Netgear 64-5G, but after resetting my laptop, all of other networks are showing but the one mentioned above. The mystery here is that my TV is still using the ne...
Jul 13, 2022Guru - Experienced User
What router do you have? (actual model)
What wireless card is in your laptop? after resetting the laptop, you might be using the stock driver for the wireless card and it not be showing the 5ghz signal. so what wireless card is in it and what driver is installed for it (driver version)?
