one2busy's avatar
one2busy
Why over 200 smurf attack packets from Comcast IP's within a day.
For about a two weeks, I've been getting 100's of smurf attack packets on my Netgear R7000P NightHawk.  The ip's seem to be comcast's.
On Oct. 29, 2022 there seems to be over 200.
Is there a setting I can change to prevent this, or any other suggestion?
Ed Roberts
  • michaelkenward's avatar
    michaelkenward
    Prevent what? The attacks? Those reports?
    Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
    Search - NETGEAR Communities – DoS attacks
    Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
    Here is a useful tool for that task:
    IPNetInfo: Retrieve IP Address Information from WHOIS servers
    If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
    • microchip8's avatar
      microchip8
      Master
      False positives. NG is famously known for that. Either disable logging of these or completely disable DoS protection.
      And yes michaelkenward processing/dropping/blocking at iptables levels is far more expensive than just logging somme entries in the logs
      Besides, what's the point keeping it on if 85-90% are false positives? The rest 10-15% is just yoour regular spambots testing trying to get in. It's useless
        michaelkenward
        Keeping what on? Protection or logging?
