FWIW's avatar
FWIW
Wi-Fi Authentication Error
Netgear Nighthawk X6 R8000 Firmware Version V1.0.4.46_10.1.63 Smart Connect Enabled   We have two Samsung S10s and both display the same problem.  They will be connected and working fine, then af...
  • FWIW's avatar
    FWIW
    Jan 21, 2020
    I don't know which circuit they were connected to, but haven't had a problem since I disabled the Smart Connect
